Please provision my phone (Moto G7 Power) for VoLTE
  • October 21, 2024
  • 603 views
Trevor D'Arcy-Evans
Lost the ability to make & receive phone calls about a month ago.  My phone is:
  • Moto G7 Power
  • Android 10
The phone supports 4G, so it should just be a matter of the network operator (id) provisioning the phone for VoLTE
Best answer by Tyler C
Hey there @Trevor D'Arcy-Evans, welcome to Community!
we’re sorry to hear you’re having issues with calls.
This is likely due to the 3G turn off that began rolling out recently. You can check if this is the case in your area below:
If you have one of the phones from the below list, then 4G VOLTE and Wi-Fi calling should be able to be selected and work, and calls should still work:
If the issue persists after following the troubleshooting above and confirming if your phone is approved, then please let us know here so we can investigate further. If your phone isn't listed above, you'll need to upgrade/get a new phone I'm afraid to receive calls. Texts and data should continue to work either way.
  • October 23, 2024
