POCO C75 Compatability with ID Network
  • February 13, 2025
  • 6 replies
  • 105 views
  • 16 replies
This model was launched in December 2024 and is not on the ID Network compatability list.
Has anyone bought it and does it work?
Hi ​@tankman
Have you checked to make sure VoLTE is enabled on the phone?
To check if VoLTE is enabled on a POCO C75, go to your phone's Settings > Mobile Networks > Preferred Network Type and ensure that "LTE/4G" or "LTE/4G+" is selected; if VoLTE is available on your network and SIM, you should see an option specifically labeled "VoLTE" which can be toggled on or off.
If not, then this is the first thing you have to do.
If it is, then it may be down to the incompatibilty of the handset with the iD Mobile network. Even if a handset is not ‘supported’ it is hit or miss if it actually works as some do and some don’t.
Good luck x
Forum|alt.badge.img+1
  • Helpful
  • 10 replies
  • February 14, 2025
It’ll most likely work ​@tankman, BUT it may not be compatible with VoLTE on 3UK (iD’s Network) which is required to make calls.
  • Helpful
  • 10 replies
  • February 14, 2025
^^ VoLTE is needed as 3G has been switched off.
  • 16 replies
  • February 14, 2025
Thank you
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
  • Silver Contributor
  • 358 replies
  • February 15, 2025
Hi ​@tankman
Good luck x
  • 16 replies
  • February 15, 2025
Decembersangel72 wrote:
Hi ​@tankman
Good luck x
Thank you very much 🙂
Forum|alt.badge.img+21
  • 2311 replies
  • February 16, 2025
Hello ​@tankman
Thanks for posting.
It looks like our wonderful member have been able to assist with your query.
Please reach out if you have any further questions.
Nat
