This model was launched in December 2024 and is not on the ID Network compatability list.
Has anyone bought it and does it work?
Have you checked to make sure VoLTE is enabled on the phone?
To check if VoLTE is enabled on a POCO C75, go to your phone's Settings > Mobile Networks > Preferred Network Type and ensure that "LTE/4G" or "LTE/4G+" is selected; if VoLTE is available on your network and SIM, you should see an option specifically labeled "VoLTE" which can be toggled on or off.
If not, then this is the first thing you have to do.
If it is, then it may be down to the incompatibilty of the handset with the iD Mobile network. Even if a handset is not ‘supported’ it is hit or miss if it actually works as some do and some don’t.
Good luck x
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
