Poor Indoor Coverage
up until about two week ago i had indoor coverage.
that has now gone but outside coverage is good as is the coverage signal
Best answer by Kash
Hi @clalewis,
There is, at times, heavy usage in this local area. As a result, you may experience varying data speeds depending on how many customers are connecting to our network via your closest mast.
We’re always working to improve our network and aim to provide the best experience possible.
Please can you contact our Live Chat Team HERE
  • September 5, 2024
Hi @clalewis,
I would advise checking the network status checker as it seems that work may be being carried out.
If no issues show it may be worth trying a replacement SIM.
  • September 6, 2024
Thanks for your answer.
Network checker shows good coverage.
To get another sim would be to much hassle.
Its just poor service for id
  • September 9, 2024
Hi @clalewis,
Did you check the network status checker?
Testing a new SIM is advised to eliminate a faulty SIM or handset.
  • September 10, 2024
still no indoor cover, over three weeks now.
area cover is good
to try another sim is not a valid  option -  to  much hassle and extra cost
  • 4297 replies
  • September 11, 2024
Hi @clalewis, sorry to hear that.
Have you tried the numerous troubleshooting methods available via this link below to see if they help at all?
https://community.idmobile.co.uk/troubleshooting-177
  • September 12, 2024
I have tried everything possible but still no indoor coverage.
Its as if something or someone is blocking the signal.
Coverage is good everywhere else, even 300 miles away inside a railway station
  • 4297 replies
When you have no indoor coverage, does nothing work at all?
I.e, can you not make calls/receive them, send texts/receive them, or use data at all?
Does it state you have 0 bars, or state if you’re on 3G, 4G or 5G, or simply nothing there?
Can not make calls or send text from within the house but can if standing outside.
can receive calls and text including whatts app messages and calls within the house
The signal is good
3g and 4g is available
  • 8408 replies
  • September 13, 2024
Hi @clalewis
Please could you let us know the postcode(s) where you have this issue?
  • September 14, 2024
SE18NA
  • September 17, 2024
Hi @clalewis,
