Poor network Speeds/Data connectivity
I've noticed in my area for the last few weeks (maybe months) that the 4G data speeds and latency is very poor and/or non existent... The signal reported by my phone is 2 to 3 bars normally but even with full strength the speed is useless.
If I switch over to 3G only then everything works fine but that's being switched off soon so I can't use that long term.
Could someone investigate please.
It's not just me either as my wife is on iD and she has the same issue.
I checked on the Three mobile service checker but nothing is reported.
Many Thanks!
Best answer by Tyler
Hey there @Soamesy, welcome to Community!
We're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know and we can investigate further.
  • 3978 replies
  • June 24, 2024
  • July 29, 2024
Solution, I'm going to buy other network sim for data  and use id for calls only.
  • 8314 replies
  • August 6, 2024
Hi @Kenw
We’ve responded to your post here.
