Poor phone quality
Ash799
Hi, I am recently experiencing poor phone quality for all calls between my handset and a landline number. People on the other end cant seem to hear me clearly at all and keeps cutting off. I am not sure why this is and this tends to happen even when i have good signals. I have noticed the connection between mobiles are clear without any issue.
Its very frustrating because I have to speak with companies with landline numbers and they cant hear me at all.
I am currently using Samsung S23 Ultra and I don't believe its an issue with handset.
  • 8275 replies
  • August 6, 2023
Hi @Ash799,
We would would firstly advise checking the coverage and network status via the link below:
If everything seems fine then it may be best to test the SIM in a different device as it may be a handset issue.
Should you have the same issue after trying it in a different handset, we can look at trying a replacement SIM.
Ash799
  • August 13, 2023
Hi Thank you for replying. My area has good coverage so I don't think its a network problem and I also tried using a different handset but the problem remained the same.
I an unsure if new sim would resolve this issue but I am happy to explore this option.
if the new SIM is having the issue what would be the next step?
Mohammed H
  • 7962 replies
  • August 14, 2023
Hey @Ash799,
We can raise this to our TechTeam and troubleshoot further but just so we can rule this out, what’s the full postcode of the area? We’ll check if there’s any ongoing work in your area.
Can you also test your SIM in a different phone and a different network SIM in your phone just to rule this out also
Ash799
  • August 14, 2023
My poscode is M12 4WG and the signal is very weak when I'm inside, which wasn't the case when I first purchased SIM.
As mentioned previously the problem remained the same when I tested on a different handset
  • 8613 replies
  • August 15, 2023
Hi @Ash799
