Poor reception
Jack O'Brien
Hello,
Recently (over about 1/2 weeks) I've noticed that my mobile reception in my flat is worse than it used to be. Currently I usually have the "emergency calls only" message at the top of my phone which never used to be the case. I didn't think much of it to begin with as I assumed there may have been work going on but it still hasn't resolved.
Best answer by WelshPaul
I expect to see a lot more posts like this over the coming months. Three are preparing to shutdown their 3G network, and so a lot of work needs to be done on existing masts to improve 4G and 5g services over the coming months.
https://www.ispreview.co.uk/index.php/2022/05/three-uk-confirms-plan-to-switch-off-3g-mobile-service-by-2024.html
However, I'm not saying that the above is the reason for your reduced service @Jack O'Brien, it could be a local area fault.
  • 12543 replies
  • May 17, 2022
Check the mobile network for service disruptions in your area - Network Status Checker (by three - iD Mobile's network partner).
  • 3101 replies
  • May 17, 2022
