I'm trying to order a sim, but I've been asked for my address history in the last 3 years. I understand that's needed for the credit check, but I've been living in the UK for 2 years. Usually, I have no problems with using the previous address from my country, but the registration form is not accepting that.
Is there any way I can solve that or I just can't buy your sim?
Roberta
Log in to the iD Community.
Social Login
