Problem connecting to pc by usb cable
  • April 1, 2025
  • 209 views
I have just purchased a Samsung A16.
I have enabled developer mode.
I have set the USB default configuration to “transferring files”.
I have connected a USB cable to my PC
My friends A15 connects fine. So the cable is Ok and the PC has a Samsung driver
My A16 dies not seem to trigger windows file manager.
What am i doing wrong - or have not done ?
Best answer by Tom
Hi ​@rgtr
On behalf of Natalie.
Some USB cables will only be rated for charging and not for data transfer, it’ll be worth double checking before you buy.
  • April 2, 2025
Hello ​@rgtr
Thanks for posting.
I have taken a look into this and you would be best to speak to Samsung directly regarding this issue.
I had located some troubleshooting but this mostly pointed to the cable being defective which you have advised it isn't.
Natalie
  • April 2, 2025
Natalie
Despite the A15 connecting Ok, I found I had a USB / USB-c adapter plug.
Used that and all is fine.
There seem to be a lot of dodgy usb-c “cable alikes” around !
Problem solved.
But the fact that the A15 did connect threw me.
Richard [aged 78 by the way]
  • April 3, 2025
Hi ​@rgtr
Glad to hear.
  • April 3, 2025
didn’t see your answer - or was it on behalf of Natalie.
The duff cables do however allow charging . .
Richard
  • April 4, 2025
Hi ​@rgtr
