problem with website
I cannot get access to the id mobile.  I get this message. Can anyone help?
Best answer by Michelle H
Hi @Jojo217
We have now fixed this issue, you should now be able to access your online account.
We are sorry for any inconvenience caused.
Michelle
iD Mobile
Michelle H
  • 1540 replies
  • March 5, 2021
Hi @Jojo217
Michelle
iD Mobile
  • March 5, 2021
Hi it still doesn't work.
Will R
  • 4103 replies
  • March 6, 2021
Hi @Jojo217,
Have you tried clearing your cache and cookies?
Is this on multiple devices and browsers?
Will
  • March 6, 2021
I've done that'd it still doesn't work. It was Samsung Internet browser I normally use.  I've gone to use chrome and it works so I'll stick to that.  Thank you
Will R
  • 4103 replies
  • March 6, 2021
Cheers @Jojo217,
Odd that it wasn’t working on your usual one. I’m sure the folks are aware and working on a fix as we speak. Do you know if you’ve got the latest update on your phone?
Will
  • March 6, 2021
Yes everythings up to date. It worked when I first went on your site to order the sim cards but since then when I try to go on it always comes up with that message. Its happened for a while now.
Mohammed H
  • 7962 replies
  • March 7, 2021
Hello @Jojo217,
Try a different browser.
It’s related to your settings in the browser/cookies/cache.
If you try downloading Google Chrome and using that browser for your phone it should work.
Or try Incognito mode in the Google Chrome browser.
