problems receiving calls. Says person is on another line.
Josh Bird
Hi Whenever anyone rings me they get a message saying that ‘The person you are trying to call is on another line’ - however, im not.
I have tried toggling wifi on and off and have reset my network settings, but neither has helped.
  • 12248 replies
  • March 30, 2023
Have you checked your iD SIM card is not broken or damaged @Josh Bird
Have you checked what happens if you use your iD SIM card in a different device?
You might need replacement SIM card.
  • 8352 replies
  • March 31, 2023
Hi @Josh Bird
Does this happen with multiple different numbers attempting to call you?
Have you tried the SIM card in another device?
