rcs issues after porting - honor 9
Rodger Quinn
I had my number ported across to the id SIM. RCS messaging still shows as the original id number. I've tried uninstalling the app, clearing cache, unregistering the original id number from my Google account, pretty much everything that I've seen suggested online, to no avail. When I click to verify my number and add by ported number, it comes up saying RCS messaging isn't available on this device even though it does work on the original id mobile number.
Any ideas?
Best answer by Tom
Hi ​@Rodger Quinn
Sorry to hear this, I’d recommend the following;
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
  • 12248 replies
  • April 25, 2025
Maybe just turn the RCS messaging feature OFF, and use SMS text messages instead, ​@Rodger Quinn
Unfortunately, when a registered device changes its mobile number, the Google servers don’t always immediately recognise this event.
Leaving RCS turned OFF for at least weeks could fix the issue.
Final thought, have you checked the mobile numbers and devices, which Google have stored in your online Google Account? Google keeps lots of information about an account holder.
  • 8352 replies
  • April 25, 2025
Hi ​@Rodger Quinn
