Realme X2 phone... not able to receive or make calls
  • January 23, 2025
  • 146 views
Samantha Jane
After today’s outage, and suggested remedies.  I am still unable to make or receive calls.  Is this because my phone in not compatible with the changes or because I have not managed to alter the settings. Does anyone know please if the Realme X2 phone is compatible before I purchase another phone?
thanks in advance
Best answer by Anonymous
Do not worry it’s not your phone I thought the same bit it’s the network that’s is down 3 so annoying and very inconvenient!!!
  • 59 replies
  • January 23, 2025
  • January 23, 2025
Samantha Jane
  • January 23, 2025
Thanks soo much… I went through all their advice on the page which mentioned going into settings and changing this that and the other… but the menus just dont match my phone.  I am hoping you are correct and it will return to normal soon.  Thanks for the message :)
Forum|alt.badge.img+21
  • 2277 replies
  • January 24, 2025
Hi ​@Samantha Jane
We're aware of a network wide issue affecting services, unfortunately we do not have a time frame of when this will be resolved.
We apologise for any inconvenience caused and want to assure you this is high priority and our team are working hard to get this repaired as quickly as possible.
All updates on this issue can be found here
Nat
