I shall be travelling to Bangladesh. Are my incoming calls from the UK free?
receiving incoming calls in Bangladesh
Best answer by Tyler C
Hey there
Charges for all calls, texts and data can be found here:
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
