Repeated "Unable to connect to iD Mobile" error.
Hi.
I’ve been with iD mobile for a few months but have never been able to use the app due to the repeated "Unable to connect to iD Mobile" error.
My phone is Android 10 and the minimum requirement is Android 9, so that should not be the issue.
I’ve run “Reset network setting”, but that didn’t work.
I’ve uninstalled and reinstall the app before and after resetting the network settling but still go the same error.
Is anyone able to help?  I’ve attached an screenshot with the error code.
Best answer by Daz_S
@Bethany1 If you get no joy in sorting this out via Live Chat you could try the following:
(and although I could be wrong I think you’re using a Samsung phone)
On your phone go to SettingsApps → scroll down and click on the iD Mobile app → click on Storage → (at the bottom) click on Clear cache AND Clear data (you will get a warning on the latter, ignore it) → click the back button and now Uninstall the iD Mobile app from that screen. Restart your phone. Download the app again and see if it now works.
If it does then all’s good
If it doesn’t then sorry for wasting 10 minutes of your time.
At the time of writing the latest App version is 6.1.3
  • 4175 replies
  • October 24, 2024
Hey there @Bethany1, sorry to hear you’re having issues with the app.
How long have this been an issue for please?
Are you able to login via our website?
  • October 24, 2024
Hi @Tyler,
I can log on via the website and view my bills and payments.
The app has never worked for me and it’s 3-4 months since I’ve been with iD Mobile.
I get the same error message, the error code starts with 500 but the rest of the digits change.
Forum|alt.badge.img+21
  • 2215 replies
  • October 25, 2024
Thank you.
Can you please remove the app and then download it again.
Once you have done this, please open the app using mobile data and not WiFi.
Let us know how you get on.
Nat
  • October 26, 2024
Hi @Natalie W,
I uninstalled, reinstalled and logged into the app with Wifi off and got the same error, see attached.
  • 2215 replies
  • October 28, 2024
Thank you.
To confirm, is this happening when initially opening the app or when you are attempting to login please?
Nat
  • October 28, 2024
Hi @Natalie W,
After installing the app I have absolutely no problem logging in, no error messages, no warnings
Immediately after the login, when the app tries to open the white screen with the error messages appears (see screenshot from last message).
When I close and reopen the app then I see the green iD Mobile screen with the error message (see screenshot from first message).
  • 4175 replies
  • October 29, 2024
Hey @Bethany1, thank you for confirming.
And this is only via the app this happens? It doesn’t happen when logged into the website?
  • October 29, 2024
Hi @Tyler, Yes this is an app only error.  I don’t have an issue with the website.
  • 4175 replies
  • October 30, 2024
Hey @Bethany1, sorry about that.
Have you tried contacting our live-chat and have them raise this with our technical team for you at all? They can give instant responses there:
If you’d prefer, we can PM you here to investigate further also.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • October 31, 2024
  • 2215 replies
  • November 1, 2024
Thank you for your assistance @Daz_S
@Bethany1 Please do let us know how you get on.
Nat
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 1, 2024
And as of earlier this morning the latest version is 6.2.0 🤐
