Replacement sim
  • February 26, 2025
  • 144 views
Craig Gretton
I got a replacement sim from curry's yesterday as I normally use esim.
I've activated it and put it in my phone but doesn't work and just says emergency calls only or no service. Any help appreciated please.
Best answer by MZone
Try using the iD online Live Chat service, to speak to a customer adviser ​@Craig Gretton
The advisers work until 9pm on weekdays - just tell the 24/7 chatbot you’d like to “talk to a person”. ​
Failing that might be a faulty SIM card. Why did you change from eSIM to physical SIM?
You can order a replacement eSIM through your account and they will email you the QR code.
MZone
  • 1101 replies
  • February 26, 2025
Can take a few hours to activate. Have you turned the phone off/on?
Craig Gretton
  • February 26, 2025
Yea done all that yesterday. Even got the text through as i can use the esim.
MZone
  • 1101 replies
  • February 26, 2025
  • 3978 replies
  • February 27, 2025
Hey there ​@Craig Gretton, sorry to hear your new SIM isn’t working yet.
Are you still having issues now?
