Restrict use of network overnight
  • August 15, 2024
  • 139 views
Hello,
Can I use 'block sim' to stop the mobile network being used overnight, and then use 'unblock' in the morning. I have not set up daughter's phone with parental controls, and want to stop it from being used into the early hours.
Best answer by Tyler
Hey there @Kevbrad, thank you for reaching out.
You can have your SIM card blocked by us, and unblocked by us, but this would mean contacting us daily and us doing so, which may end up causing possible SIM issues.
We therefore don’t really have an efficient way of blocking the SIM or phone every so often, only completely really.
Sorry about that.
  • 3991 replies
  • August 21, 2024
Sorry about that.
