ring in
Got a new SIM .it works in the UK but while I'm in Dublin I can ring out but nobody can ring me
Best answer by Natalie W
Thank you.
Has this been tested with multiple callers?
What message do they get when attempting to call you please?
Natalie
  • 12545 replies
  • March 3, 2025
Others have posted in this forum, from different EU destinations, about having the same issue, ​@Liam kelly - perhaps there’s a network issue impacting in-coming calls for some iD customers, while roaming.
  • 8561 replies
  • March 3, 2025
Hi ​@Liam kelly
Sorry to hear that, what happens when they try to ring you?
Is it multiple people who have tried ringing you whilst roaming or just one?
Are they able to ring you whilst you’re in the UK?
  • 13 replies
  • March 3, 2025
Thank you .in the UK I can ring out and EU can ring me .when I'm in the EU I can ring UK but nobody can ring me from UK or EU
  • 13 replies
  • March 3, 2025
Customer service was not much help
  • 13 replies
  • March 3, 2025
Thank you for your replies
  • 2349 replies
  • March 4, 2025
Thank you.
Natalie
  • 13 replies
  • March 4, 2025
Yes multiple callers from the UK and EU .it's saysi can't take the call
  • 13 replies
  • March 4, 2025
Yes .multiple times from the UK and eu
  • 13 replies
  • March 4, 2025
Natalie W wrote:
Thank you.
Natalie
Yes it has .from the UK and EU
  • 13 replies
  • March 4, 2025
Natalie W wrote:
Thank you.
Natalie
Yes .from the UK and EU .says I can't take the call
  • 8561 replies
  • March 5, 2025
Hi ​@Liam kelly
Okay, are you on an iPhone?
It may be worth ensuring in the settings that your number is the correct one (and that +44 is at the start of the number, not 0).
Settings > Apps > Phone > My Number
  • 13 replies
  • March 5, 2025
Tom wrote:
Hi ​@Liam kelly
Tried that tom.thanks
  • 8561 replies
  • March 5, 2025
Hi ​@Liam kelly
Okay, please could you try dialing the below code;
#35*0000#
  • 13 replies
  • March 5, 2025
Tom wrote:
Hi ​@Liam kelly
#35*0000#
That stopped call barring but people still can't ring in
  • 8561 replies
  • March 5, 2025
Hi ​@Liam kelly
Okay, are you abroad currently with this issue?
  • 13 replies
  • March 5, 2025
Tom wrote:
Hi ​@Liam kelly
 I am tom
  • 2349 replies
  • March 6, 2025
Thank you ​@Liam kelly
Are you using a physical or eSIM please?
If its a physical SIM do you have the option to try this in another handset to see if you have the same issue?
Natalie
  • 13 replies
  • March 6, 2025
Natalie
I tried that too .when I go to sim status I can't put my number on
  • 2349 replies
  • March 6, 2025
Which handset have you tested the SIM in please?
Natalie
  • 13 replies
  • March 6, 2025
Natalie
Oukitel wp28e
  • 2349 replies
  • March 6, 2025
Thank you, this doesn't appear to be an approved iD Mobile handset sorry. Is this the handset you are using?
If not, can you please confirm the make and model for your device?
Natalie
  • 13 replies
  • March 6, 2025
Natalie
Ok .thank you .I will try a Samsung phone at the weekend and let you know .thank you again for your help .Liam
  • 2349 replies
  • March 6, 2025
Natalie
