Roaming
How do I know if I can use my plan in the USA?
Best answer by Tom
Hi @Shivvy1
You’ll be able to use your iD Mobile SIM card while in the USA, however will incur the above charges shown by @andewhite according to your usage.
  • 12167 replies
  • May 22, 2024
Unfortunately the USA isn’t one of iD Mobile’s inclusive roaming destinations, @Shivvy1
You can’t use your plans allowances in the USA.
If your account bill cap is more than £0, and you use your iD SIM to roam in the USA, iD Mobile will charge you as follows:
Huawei and Honor handsets may not work in the USA. The US Government has decided handsets from these companies might be a threat to US security.
  • 8225 replies
  • May 27, 2024
Hi @Shivvy1
