Roaming
  • April 16, 2025
  • 33 views
Ade1210
Ok. I was going to Ireland from the UK and at the UK ferry pory i turned on roaming as i can use my allowance in Ireland. Then mid way across i get a message that i was near my cap and had £25 lobbed ontop of my monthly bill. Whats this all about? Thanks
Best answer by Siân
Hi ​@Ade1210
This will be because you will have used roaming while at sea.
When you’re at sea, we recommend you don’t use your phone, and put it in flight/airplane mode until you get to shore. This is because using your phone while at sea can be very expensive.
Ferry and cruise operators often use their own phone network that’s operated via satellite. Connecting to a satellite network is much more expensive then connecting to a land operated network.
You can find out more here - International Calling & Roaming Charges | iD Mobile Network
I hope you enjoy your trip!
Siân
Forum|alt.badge.img+4
  • 788 replies
  • April 16, 2025
Hi ​@Ade1210
