Roaming doest work for data
Roaming has never worked for data had the phone 15 months calls and text work data not I have done all the things suggested on community! I have same phone and plan for son it works, but he is not on holiday with me! Help I need data, many thanks Rebecca
Have you tried a NETWORK RESET on the phone with your iD SIM, ​@rebeccarothman?
The phone user guide should explain all the reset procedures.
This community article might help.
  • 12535 replies
  • April 22, 2025
  • 8256 replies
  • April 22, 2025
Hi ​@rebeccarothman,
Is Roaming enabled on the handset and the iD Mobile app/account?
If it works for your son but not you it’s likely to be a settings issue. It may be worth comparing your network settings and APN settings.
