roaming in china and vietnam
I am travelling to Shanghai on 14th June, from there to Hanoi on 19th June and will stay in Vietnam till 9th July. I need to get roaming for these destinations while I am away. What do I need to do?
Best answer by Lauren K
Hi @Tony Chu. @andewhite is correct here. Roaming outside of the EU can be expensive. If you haven’t already, it could also be worthwhile to consider a local SIM.
More information on roaming charges can be viewed via the link below:
International Calling & Roaming Charges | iD Mobile Network
-Lauren
  • 12432 replies
  • June 11, 2024
Roaming with your iD SIM in China and Vietnam will be expensive, @Tony Chu
My suggestion is buy a travel data-only eSIM for your handset, assuming it’s eSIM capable, which covers these countries.
Google “travel eSIM” to see some options. The eSIM plans from https://roamless.com look interesting.
Lauren K
Forum|alt.badge.img+19
  • 479 replies
  • June 25, 2024
-Lauren
