roaming not working
Despite turning roaming on I'm not getting any connection while being in South Africa. Can you please let me know how to resolve this
Best answer by Matthew T
@Rudik -
Please try these troubleshooting steps.
  • September 17, 2024
When loading a webpage ith roaming on I'm getting an error
The web page at https://www.bbc.co.uk/ could not be loaded because:
net::ERR_CONNECTION_RESET
  • 8406 replies
  • September 19, 2024
Hi @Rudik
Sorry to hear this, have you tried resetting network settings?
Have you tried manually connecting to the following networks while in South Africa;
MTN
Telkom
  • September 20, 2024
Tried that as well Tom  ut same results.
I also see a little bar graph with a question mark and as notification 'sign in into network xxx' but when clicked on you don't get a sign in.
Rudi
  • September 24, 2024
Hi @Rudik,
Do other websites work?
Can you try and access bbc.com? You may not be able to access the UK site whilst abroad.
Hi Kash,
Sorry but any site won't work
Thanks,  Rudi
  • 8406 replies
  • September 30, 2024
Hi @Rudik
Is your bill cap high enough to support charges for data roaming whilst in South Africa?
Hi Tom,
Bill cap is high enough so not a problem.
Cheers
Rudi
  • 4175 replies
  • October 3, 2024
Hey @Rudik, sorry to hear that.
Do calls and texts work okay, just not data?
How long have you been roaming for and when did you join us?
  • October 3, 2024
Txt and calls are working and I've been ID customer for several years
  • 1880 replies
  • October 8, 2024
@Rudik -
  • January 1, 2025
I am in Portugal and cannot get roaming data in my router. Works fine in UK. International roaming on. I have inclusive plan.
  • January 1, 2025
Hi  ​@Corjenny,
We can’t guarantee that your SIM will work in a router.
It’s likely that you need to change the APN settings if possible.
  • January 1, 2025
Ok. It works fine in the U.k. though.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • January 1, 2025
That might be because the SIM is waiting for an ‘automated rate advice’ SMS from iD and it can’t get the text being as its in a router.
What I’d try is switch the router off, eject the SIM. With a phone (switched off too) put the routers SIM in the phone and switch the phone on. Wait for the rate advice text. Turn the phone off, pop the SIM back into the router and see if it then works.
  • 4175 replies
  • January 2, 2025
Hey ​@Corjenny, as mentioned, we cannot guarantee it’ll work.
So if it works in the UK, that’s a positive at least as we can only advise that it may or may not work.
  • January 2, 2025
Hi. My router does receive messages and it has not acknowledged Portugal.
I had a message as we travelled through France and Spain.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • January 2, 2025
Of the networks available in Portugal you should see these:
MEO or NOS or Vodafone
If you manually scan for networks try picking the 2nd or 3rd one on the list rather than the 1st one.
Peter49
  • March 27, 2025
Ive tried all the options in the website support but no luck .I cant access the automatic button which has a continually spinning wheel.
Peter49
  • March 27, 2025
I will cancel subscription and go back to 3mobile if no success
  • 4175 replies
  • March 28, 2025
Hey there ​@Peter49, sorry to hear that.
Can you explain your issue further so we can help as best as possible?
Peter49
  • March 28, 2025
I’m back in UK now. I could not access internet when in Italy. I tried all the tips on line but no joy. I need to speak to someone to go through my settings to check all are correct. It’s an iphone 12 . I checked data roaming was switched on phone and ID account. I turned off and on to clear. I have eSim but not sure if it is working, though I get wifi and hotspot OK.
I’m going to cancel when my month is up as no customer support is annoying. I’ll go back to 3 where I was before without any problems
  • 4175 replies
  • March 28, 2025
Unfortunately, it’s difficult to troubleshoot and check settings etc if you’re already back in the UK I’m afraid.
If you have issues in the UK, please let us know and we can investigate further. Or, please get in touch right away if you have issues abroad again so we can check it out further for you then.
