robert bridge
  • November 22, 2024
  • 9 replies
  • 85 views
Bob Bridge
i can not make calls or reveive call, but have 4g internet, have replaced the sim with a new one still the same.
Best answer by Bob Bridge
Hi A25 works fine at last thanks for your help Bob.
Daz_S
  • 1627 replies
  • November 22, 2024
Hi there ​@Bob Bridge
Have you enabled VoLTE?
Please read this:
If you don’t have the ability to enable VoLTE, then this might be due to using an unlocked phone from another network
Bob Bridge
  • November 22, 2024
Please read this:
if i have full internet 4g VoLTE I must have it?.
Daz_S
  • 1627 replies
  • November 22, 2024
So you have a setting on your phone which states something along the lines of VoLTE for SIM and this is enabled?
What phone are you using ​@Bob Bridge?
Bob Bridge
  • November 24, 2024
I have a moto g7 plus I have looked  on phone network and the 4G is ticked, but no joy ,internet perfect, so I have put the SIM in my S22, all works fine, so have ordered a galaxy A25 coming today to replace the moto, so hopefully it will work in that phone. thanks Bob.
Daz_S
  • 1627 replies
  • November 24, 2024
Knowing about the phone has revealed the answer ​@Bob Bridge
According to iD’s compatibility list the G7 Plus isn’t one that would work!
Motorola G7 Plus N/A N/A
The N/A means that phone doesn’t have VoLTE or WiFi calling functionality. Its the lack of VoLTE that’s caused the issue.
So by upgrading (as you’ve said) you should finally put your issues to bed.
  • 8484 replies
  • November 25, 2024
Hi ​@Bob Bridge
How’s the Samsung A25 been since?
Bob Bridge
  • November 26, 2024
Daz_S
  • 1627 replies
  • November 26, 2024
That’s great to hear its working fine ​@Bob Bridge 👍
  • 8484 replies
  • November 26, 2024
Hi ​@Bob Bridge
Glad to hear the A25 has been working.
