same network number transfer
  • September 23, 2024
  • 3013 views
I’m on sim only plan I wanted to buy a device plan using u switch and wanted to keep my current number. But they said same network switching is not available, how do I transfer my old number to new ones?
Unfortunately @Syed islam, you can’t move a number from one iD account to another iD account, and a PAC can only be used for transferring a number between different service providers.
Port out the number you want to keep, to another mobile network, and then port it back to iD Mobile for your new SIM only plan.
  • 12543 replies
  • 8552 replies
  • September 26, 2024
Hi @Syed islam
Unfortunately as suggested, porting directly from an iD Mobile plan to another iD Mobile plan isn’t possible.
It may be worth trying the above from @andewhite.
