Got a new Samsung 23 but it keeps dropping out of home WiFi continuously. Any ideas on how to resolve
samsung 23
Best answer by Kash M
Does it connect to other Wi-Fi networks fine?
Are you able to test another device on the Wi-Fi Network?
If the issue is only with your handset, the handset may be faulty.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
