saved voicemails - how do I delete it?
How do I delete a voicemail I saved accidentally?
Best answer by Mohammed
Hello @emmajohnson
You can dial 123 or your Voicemail contact if saved then you will be able to listen to your voicemail and be given the option to a) save it and move on or b) delete it
  • 7962 replies
  • May 3, 2023
Hello @emmajohnson
  • Helpful
  • 11 replies
  • May 3, 2023
Hi, it just says I don't have any new voicemails. But ages ago when I finished listening to a voicemail that was left for me I accidentally saved instead of deleting it so I just need it gone
  • 12167 replies
  • May 3, 2023
Call voicemail, then listen to your SAVED voicemail, and press 3 while doing this.
The voicemail system should respond with something like “message deleted”.
Good luck @emmajohnson
  • Helpful
  • 11 replies
  • May 3, 2023
Yes but what do I press to listen to my saved voicemails?
  • 12167 replies
  • May 3, 2023
When you call voicemail, if there aren’t any NEW messages the system offers some options, one of which is to listen to your saved messages.
  • Helpful
  • 11 replies
  • May 3, 2023
Hi, none of the options available allow you to even access your saved voicemails. But I know I have at least one from when I listen to a new voicemail it always says I've got one.
  • 12167 replies
  • May 3, 2023
If you’ve got no new voicemail messages, but have 1 or more saved voicemail messages, option 1 allows you to listen to the saved messages.
If option 1 is not available, sounds like your voicemail is out-of-sync.
One possible solution is turn OFF voicemail in your online iD account.
Leave it OFF for 3-4 days, before turning ON your voicemail.
If that doesn’t fix the issue, I suspect iD Mobile will need investigate further.
Could take a while before this gets fixed - good luck @emmajohnson
  • 8225 replies
  • May 4, 2023
Hi @emmajohnson
Please let us know how you get on with the above suggestions from @andewhite.
