Received this…. Network Provider Voicemail then a call button. This voicemail message cannot be deleted delete. My “ real voicemail” msgs says I do not have a voicemails. The red button will not delete.
Any advice, help I would be very grateful.
Best answer by Uma
Hello, thank you so much for your quick reply. It appeared as a voicemail message, with red button
notification on voicemail icon. The message itself was unusual in that it did not display in usual voicemail format.
In the end after a few hrs trying to sort problem, I went into my account at ID mobile and unckecked
the box for allowing voicemail messages. Then in phone settings I disabled the red badge notification
button. I then restarted Iphone, then completed a systems update. Voicemail still would not delete. Red
button gone.
This morning checked phone and voicemail gone!
It would have been so easy to have touched the call link on the voice mail and could have been malware,
phishing scam or ID theft. It was very suspicious. Hope this helps anyone who experiences anything
similar.
I have switched my voicemail back on.
Best regards, Uma
