Hello, I am overseas for a month and I meant to activate a voicemail msg on my phone before I came away. I am now in Thailand using a Thai SIM card. Presumably I can insert my ID mobile SIM and keep the internet/data turned off and record and activate a voicemail message. Does anyone know how to do this from overseas and how much it is likely to cost? Thank you.
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
