signal
Tracey Hale
Hello I am really struggling to get a signal in shops etc this had been going on for a while and it us not great
Can anybody please help thanks
Best answer by WelshPaul
Maybe try doing a network reset...
What phone do you have? On my Samsung device it’s here:
Settings > General management > Reset > Reset Network settings
Also, enter your post code below and check for any know problems in your area:
Mohsin
  • 2173 replies
  • June 9, 2021
Hi @Tracey Hale
We are sorry to hear this. Do you experience the singal issues when at home? Or is it only when you are out shopping? Usually when in supermarkets, the singal can vary due to the big metal framed buildings. The result is that a metal box or cage can effectively block all electromagnetic signals from outside.
-Mohsin
Tracey Hale
  • June 9, 2021
Hi no it is at home as well it needs resolving
  • 3080 replies
  • June 9, 2021
Will R
  • 4103 replies
  • June 10, 2021
Hi @Tracey Hale,
Did you try @WelshPauls advice? How are you getting on with this now?
Will
Tracey Hale
  • June 11, 2021
Hi yes done a factory reset not.working still indeed to speak to somebody ar customer care not responded sooner as I cannot get a signal thanks
Tracey Hale
  • June 11, 2021
The phone is A Samsung galaxy a20 thanks
Will R
  • 4103 replies
  • June 12, 2021
Hi @Tracey Hale,
How many bars of signal are typically showing? Is it everywhere you go, or is there ever good signal anywhere?
Will
  • September 1, 2021
Same I have an iPhone 12 and as soon as I go indoors to any building I have no service
Ryan D
  • 4571 replies
  • September 1, 2021
Hi @Traynor,
I am sorry to hear that. Have you checked out the area on our Coverage Checker here to see if the signal is limited in those areas?
