signal issues urgent calls to make
  • October 10, 2024
  • 22 views
nancy alferoff
Hi I need to make calls to HMRC and citizens advice which are very urgent and I have no signal at my home or in my garden . Wifi calls dont seem to work with these numbers. I am at risk of legal action if I cannot call them so I need a provider that can give me signal at my home without incurring exit fees  of having to leave you because i cant make these calls
Best answer by Lauren
Hi @nancy alferoff, is the issue you’re having purely with phone calls? Are texts/data affected?
If you’re unable to make any calls at all, this may be related to our 3G switch off. We’d recommend following all the steps in the article below:
3G is being switched off. What do I need to do? | Join the discussion, ask questions, share advice. (idmobile.co.uk)
-Lauren
Lauren
Forum|alt.badge.img+19
  • 479 replies
  • October 12, 2024
-Lauren
