somethings wrong with my bill
I've gone into the app to find out it's not working and I've had to change over to the new app, so I did that and I've looked at my bill and for some reason it's around £30 more than it should be. I have been trying to live chat for days but can't ever get anyone as all advisors are busy. My plan has a cap of £5 and I have unlimited on everything so I'm struggling to see how this can be. My bill is usually £59.99 and on the app it's saying my next bill is £85. I just want to be able to get in contact with someone to find out what has happened. I've never had a problem my bill it's always the same amount every month. I always pay. Can someone please help me I'm really worried
Best answer by MalcK
Try using Facebook Messenger, usually get an answer in reasonable time.
Good Luck!
  • Helpful
  • 39 replies
  • May 27, 2024
Good Luck!
  • Helpful
  • 19 replies
  • May 27, 2024
Good Luck!
I didn't know you could contact them on messenger. I'll have a look and see if I can work out how to do it. Thank you
  • Helpful
  • 19 replies
  • May 28, 2024
Just incase anyone else has this issue with the app showing their bill at the wrong price, I ended up sending a message on Facebook messenger and got a reply pretty quickly. They have said that my bill looks normal and there is a known problem with the app showing wrong information. So I feel alot better because an extra £30 on my bill was a massive shock. Hopefully this can help someone else
  • Helpful
  • 19 replies
  • May 28, 2024
beautifulluyou wrote:
Good Luck!
Thank you, I had never even thought of reaching out through social media before. This was a really helpful answer and I managed to get things sorted very quickly. I would recommend contacting through messenger to anyone having an issue as they do reply very quickly. So thank you for your help
  • Helpful
  • 39 replies
  • May 28, 2024
Good Luck!
Glad you got sorted. Please mark my reply as best answer if you don't mind.
  • Helpful
  • 19 replies
  • May 29, 2024
Good Luck!
No problem I've done that now
  • Helpful
  • 39 replies
  • May 29, 2024
Good Luck!
Thanks👍
  • 8192 replies
  • June 4, 2024
Hi @beautifulluyou and @MalcK,
I hope that your query is resolved.
If there is anything else that we can help with, please let us know.
