Speed is abysmal despite dull signal
  • November 25, 2021
  • 51 views
I just switched to iD mobile, back on Vodafone I generally got around 20 megabits down, sometimes higher, sometimes lower.
iD is getting almost unusable speeds, well below 1 megabits.
As you can see, I supposedly have full signal. Web browsing works OK but anything else is unusable.
Any ideas?
  • 12550 replies
  • November 26, 2021
Hello @yotoprules,
Have you checked if there are any network issues or problems in your area?
You can do this using the Three Network Status Checker - iD use the Three UK network.
Anyway, good luck.
  • November 26, 2021
No problems in my area apparently.
Sometimes I get 20 then it drops to like 1-2 megabits…
I’m switching back to my previous provider (Vodafone) which has a much more consistent connection.
Will R
  • 4103 replies
  • November 27, 2021
Hi @yotoprules,
We’re sorry to hear you’ll be leaving.
If you require any assistance with that though, please let us know and we’ll get right on that for you.
Will
