Split Port
  • September 16, 2024
  • 94 views
I have switched from EE, number had part ported, I can make outgoing calls but unable to receive calls or texts, when I call my number it starts reading a random mobile number? I think something has gone wrong?
Best answer by Tyler
Hey there @JoLa Yoli, we’re sorry to hear you’re having issues with calls.
This is likely due to the 3G turn off that began rolling out last week. You can check if this is the case in your area below:
If you have one of the phones from the below list, then 4G Volte and Wi-Fi calling should be able to be selected and work, and calls should still work:
If the issue persists after following the troubleshooting above and confirming if your phone is approved, then please let us know here so we can investigate further.
All working now
JoLa Yoli
Im with ID mobile for a few months and today I started having problems with receiving and making calls Tried switch off phone updated phone and still having that problem
  • 2975 replies
  • 4175 replies
  • September 18, 2024
Hey @Foakesy, we’re glad to hear all is sorted!
  • 4175 replies
