switched from O2 to ID today ! calls are not working nor text messages nor data
  • 9 replies
I have had my switch done today from O2 to ID… nothing works now unless I’m in the WiFi
Best answer by Marine
Sorted! Had to go onto settings and RESET NETWORK! As easy as that
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 462 replies
  • December 10, 2024
Transfer process may take up to midnight; assume you’ve rebooted your phone.
  • 9 replies
  • December 10, 2024
Yes I have
  • 9 replies
  • December 10, 2024
Is it normal process?
  • 12349 replies
  • December 10, 2024
Alas, UK mobile number transfers don’t happen immediately, ​@Marine
Sometimes iD can take up until 10pm on the switching date to complete the transfer.
When I switched my mobile number to iD Mobile, the switched process finished around 15:30, having started at around 11:00.
  • 9 replies
  • December 10, 2024
Thank you! Fingers crossed! It’s ever so frustrating
  • 12349 replies
  • December 10, 2024
Good luck ​@Marine - for some reason O2 seems to release mobile numbers (to be transferred) later in the day than other networks, and consequently switching from O2 gets completed later in the day.
  • 9 replies
  • December 11, 2024
Still nothing this morning 😢
  • December 11, 2024
I am in similar situation. Transferred from O2 yesterday at around midday. Rebooted iPhone due to nothing working. Now have WhatsApp and emails. I can make calls via WhatsApp. Very few outgoing calls are possible in the normal way and marked as T ? Travel but any marked P ? Primary are still with O2 WiFi calling and call ends immediately!😡 I am relieved to be keeping my original number but bit useless if I can’t use my phone to call out!!
  • 9 replies
  • December 11, 2024
This is what I have…. Can’t make or receive calls.. unless I’m in the WiFi the I can use WhatsApp!!
  • December 11, 2024
Thank you! Will have a read. 🤞
  • 12349 replies
  • December 11, 2024
Are there 2 SIM products in your phone, ​@Marine
The screenshot appears to show your phone has one active and one inactive SIM / eSIM.
Were you using an O2 eSIM? Are you using an iD eSIM?
  • 9 replies
  • December 11, 2024
I am using an id eSIM… took the o2 out of the phone
  • 12349 replies
  • December 11, 2024
Is the iD eSIM the primary or default line, for calls and SMS text messages, in your phone, ​@Marine
  • 9 replies
  • December 11, 2024
All primary
  • 12349 replies
  • December 11, 2024
Looking at your screenshots, these appear to show your phone has another SIM (in addition to your iD eSIM), ​@Marine
In addition, the iD Mobile signal reception at your location looks marginal.
Perhaps try the OFCOM coverage checker to see likely network signal strength - for all the UK networks - at your location.
https://checker.ofcom.org.uk/en-gb/mobile-coverage
  • 9 replies
  • December 11, 2024
Forum|alt.badge.img+21
  • 2215 replies
  • December 11, 2024
Hi ​@Marine
Glad to hear this issue has now been sorted for you.
Please get in touch if you have any further questions.
Nat
  • 12349 replies
  • December 11, 2024
That’s marvellous, ​@Marine
Does the phone, with your iD eSIM, now show a single signal status/strength icon?
  • 9 replies
  • December 11, 2024
Yes thank you! 4G is on .. everything is working great and the signal is already 100% better than O2. ​@andewhite
  • 2215 replies
  • December 11, 2024
Great to hear ​@Marine
Nat
