Old number will not transfer across through PAC code because it was on sim only with ID before, how do I transfer it across to my monthly plan?
Log in to the iD Community.
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
