text messages will not send
Natalie Paolozzi-Lloyd
When I try to use text messaging it says failed to send every time
Best answer by WelshPaul
Try resetting your devices network settings as instructed below.
Reset iPhone Network Settings
To reset network settings on an iPhone, follow these steps:
  1. Open the Settings app.
  2. Scroll down and tap on General.
  3. Tap on Transfer or Reset iPhone at the bottom of the list.
  4. Select Reset.
  5. Choose Reset Network Settings.
  6. Enter your passcode if prompted.
  7. Confirm the reset.
Reset Google Pixel Network Settings
To reset network settings on a Google Pixel, follow these steps:
  1. Open your phone's Settings app.
  2. Tap System.
  3. Tap Reset options.
  4. Tap Reset Wi-Fi, mobile & Bluetooth.
  5. Tap Reset settings.
  6. Tap Reset settings again.
Reset Samsung Network Settings
To reset network settings on a Samsung device, follow these steps:
  1. Slide two fingers downwards from the top of the screen to access the quick settings panel.
  2. Tap the settings icon to open the Settings app.
  3. Tap on General management or System and then Advanced.
  4. Tap on Reset options or Reset.
  5. Select Reset network settings or Reset Wi-Fi, Mobile & Bluetooth.
  6. Tap Reset settings and enter your passcode or password when prompted.
  • 8182 replies
  • April 9, 2025
Hi ​@Natalie Paolozzi-Lloyd
On every single text to every number you’ve tried?
How are calls?
Are you on an iPhone or Android?
  • 2750 replies
  • April 17, 2025
  4. Select Reset.
  2. Tap System.
