triangle port number
Does a triangle port for a number still work to keep number in 2024?
ellie.mawdsley1 wrote:
... If so, what did you do?
It’s a faff and will take several days - try these steps, @ellie.mawdsley1.
  1. Get a PAC from iD for the number you want to keep.
  2. Give the PAC from step 1 to a PAYG service provider, e.g. ASDA Mobile, giffgaff, etcetera.
  3. Wait until the number you want to keep has been successfully switched to the provider chosen in step 2.
  4. Get a PAC from provider chosen in step 2, for the number you want to keep.
  5. Give the PAC from step 4 to iD Mobile for the iD contract you’re planning to keep.
  • 2975 replies
  • July 14, 2024
It sure does!
  • July 14, 2024
Did you do it @WelshPaul? If so, what did you do?
  • 12349 replies
  • July 15, 2024
  • 8408 replies
  • July 29, 2024
Hi @ellie.mawdsley1
I’d recommend the same as @andewhite, a triangle port isn’t something we’d typically recommend, however if it’s right for you it is absolutely possible.
It’s worth noting in @andewhite’s step 2 that the PAYG service provider must be a different one to the contract(s).
