Hi , has anyone else been given the unlimited data loyalty add on ? If so does the unlimited data show in the ID App? When I upgraded I was given the unlimited data loyalty add on instead of the 10gb a month that came with the contract, however my ID mobile app only shows I have 10gb a month, and this is after about 5 weeks of starting my contract that it's still only showing 10gb of data.
Unlimited Data Loyalty add on
Best answer by Kash M
Add-ons won’t show on your data allowance.
The allowance will start to be used once you have used your inclusive data allowance.
If you are unable to use your data once the 10GB has finished, please let us know.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
