UPGRADE TO A HANDSET?
If you have poor credit - how many months of payments are required before you are likely to be accepted to take a contract out with a handset?
Best answer by Mohammed
If you’re purchasing a new contract with us, then the credit check will determine if you’re eligible to purchase a specific handset. You can consult your credit score for free on sites like https://www.clearscore.com/ or https://www.moneysavingexpert.com/loans/check-free-credit-report/
If you’re currently on a SIM only plan already and looking to upgrade, then it’s as @andewhite suggested. You can look at upgrading after 6 months of good payment history. The devices you’d be eligible for will be based on your credit score, so some handsets may not be available to purchase.
  • 12408 replies
  • May 30, 2024
It says the following on the iD website, @skinnychav.
Looks like you need at least 6-months payment history, before you might be eligible for a handset contract.
  • 7962 replies
  • May 30, 2024
