Using data abroad
Ellie Eaton
I’m travelling to Madagascar for 3 weeks, I’m wondering if there’s any way to add some data onto my account for when I’m over there and cap it at a certain amount. I’ve checked on the website and it’s £15 per MB which is crazy expensive! I don’t want to go way over that by mistake and end up paying a fortune. Any way around this? Thanks.
Just set your iD account bill cap to £0, @Ellie Eaton.
You won’t be able to incur any out-of-plan roaming charges if your bill cap is £0.
  • 12349 replies
  • July 1, 2024
  • 8408 replies
  • July 15, 2024
Hi @Ellie Eaton
Unfortunately there isn’t any sort of bundle to purchase for roaming, the roaming prices are what they are.
To avoid any unwanted charges for usage, we’d recommend the same as @andewhite above to set the bill cap to £0.
