using my phone outside of the EU.
Richard Broughton
I want to use my phone in Egypt next week,  apart from turning my roaming off & using WiFi,  is there something else I should do?  With ee I paid £10 extra for the moth & used my phone as normal.
Best answer by Tom
Hi @Richard Broughton
My best suggestion would be to adjust your bill cap to an amount you’re comfortable with going over.
https://www.idmobile.co.uk/help-and-advice/roaming-advice
  • 12167 replies
  • May 4, 2024
Okay @Richard Broughton, you’d also need to make sure your iD account bill cap is high enough to allow for the charges incurred while roaming in Egypt.
  • 8182 replies
  • May 6, 2024
