using phone abroad
  • September 23, 2024
  • 968 views
Ashleigh Kay
Can I use my ID sim only phone in Turkey
You can use your iD SIM in Turkey @Ashleigh Kay, but you can’t use your UK plan allowances to roam-like-at-home in Turkey.
The iD roaming charges for Turkey aren’t cheap, so using free Wi-Fi networks or a local SIM card might be better options.
  • 12405 replies
  • September 24, 2024
  • 8408 replies
  • September 27, 2024
Hi @Ashleigh Kay
You’ll be able to use your SIM while in Turkey, however as seen in @andewhite’s post, it’ll cost extra.
