Is there an add on package I can use for roaming in Turkey ?
Using phone in Turkey
Best answer by Matthew T
Morning
We will be introducing Roaming Add-Ons later this year. Currently, Turkey is quite pricey, you can view the charges here: https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges
Log in to the iD Community.
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
