Using Unlimited SIM in broadband router
Hello,
I’m thinking of getting a 2 year contact 5G unlimited phone data SIM and inserting it into a 5G home broadband router, such as the ZTE MC888 ULTRA or Deco X50-5G. Would this:
1) technologically be possible?
2) be allowed under the terms and conditions?
3) create any problems that I should be aware of, such as speed throttling or data capping?
I have a strong 5G signal where I live, so signal strength isn’t an issue.
Many thanks.
Okay ​@DJade, unfortunately no UK mobile network offers truly unlimited mobile data - the terms & conditions have caveats about what happens when a customer gets categorised as an excessive user, etcetera.
At iD Mobile they only provide support for SIM cards when used in a mobile phone - iD don’t support use of their SIM products in other devices.
The iD network partner (Three UK) use something called TrafficSense to manage their mobile network - read about it here.
  • 12349 replies
  • April 15, 2025
Siân
Forum|alt.badge.img+7
  • 1225 replies
  • April 16, 2025
Hi ​@DJade
We hope ​@andewhite  was able to answer your question?
  • June 5, 2025
I am confused. The answer above says ‘At iD Mobile they only provide support for SIM cards when used in a mobile phone - iD don’t support use of their SIM products in other devices.
If this is so (ie no mobile broadband), then what do I make of the page at:
https://www.idmobile.co.uk/mobile-network-speeds
...which list the speeds for (I quote) ‘Mobile and Mobile Broadband services’
  • 4175 replies
  • June 9, 2025
Hey there ​@JonSegar, we don’t offcially support the usage of our SIM cards outside our handset devices, that’s correct. However, we’re aware that some customers do still purchase our SIM cards to do so, and they can sometimes work. Therefore, we provide the information via that link you’ve sent above for these specific customers.
We can only advise that our SIM cards may or may not work outside of the approved handsets, and if they do work, then that’s great.
  • June 9, 2025
Tyler,
Thanks. You dont support the use of the SIM cards, but it sounds like you don't forbid it. I will investigate coverage in our area
  • 8408 replies
  • June 10, 2025
Hi ​@JonSegar
Nope, we don’t forbid it, however if you use the SIM card in an unsupported device we’ll be limited to how we’re able to support with it should you encounter issues.
  • June 10, 2025
Tom,
Many thanks, that makes things clear.
Forum|alt.badge.img+1
  • 142 replies
  • June 11, 2025
Hi there,
We’re glad your query has been resolved.
For any assistance, please don’t hesitate to contact us back on here.
Anika
