virtual Sim - phone number not saving
  • February 26, 2025
  • 6 replies
  • 58 views
Barry Graham
Several months ago I switched to ID Mobile from 3 and was allocated a temporary number whilst my new number was ported. I am unable to save my new number to my iPhone. I have tried switching g off iMessage and FaceTime and restarting my phone but this doesn’t work.
After entering my phone number and pressing ‘Save’, nothing happens.
I am using a virtual Sim
  • 12535 replies
  • February 26, 2025
Did you have a 3 eSIM in your iPhone when you switched to iD, ​@Barry Graham
Barry Graham
  • February 26, 2025
No I had a physical sim
  • 12535 replies
  • February 26, 2025
Assuming you’ve removed the 3 physical SIM from your iPhone, have you tried a network reset on the iPhone with your iD eSIM, ​@Barry Graham
Are you using iOS version 18.3.1 on the iPhone with your iD eSIM?
Barry Graham
  • February 26, 2025
Yes 18.3.1
Yes physical sim removed.
what will network reset achieve?
  • 12535 replies
  • February 26, 2025
Okay ​@Barry Graham, the iOS option for resetting network settings oftens helps ‘force’ the SIM/eSIM to recognise the mobile number, for your iD network connection, has changed (following a number transfer).
  • 8225 replies
  • February 26, 2025
Hi ​@Barry Graham,
Please let us know how you get on and we can assist further if required.
