voicemail notification
Since I’ve switched to ID mobile  I have a voicemail notification (red dot on corner of phone app icon)  but I don’t have any voicemails.
i can’t get rid of it.
 When I check my voicemail it says I don’t have any.
help please
  • January 3, 2025
I am having the same issue and it’s driving me insane!
  • 2349 replies
  • January 6, 2025
Hello ​@Neillappin and ​@Elisher
Sorry to hear you are not able to remove the voicemail notification.
Can you please confirm your handsets make/model?
Nat
  • January 6, 2025
I have an iPhone 13
I have reset the phone 3 times, turned my voicemail on and off three times and definitely do not have any voicemails to be listened to
thanks
Elisher
  • January 6, 2025
Hello Nat,
 thanks for your reply, my handset is an iPhone 11.
can you help me fix the issue?
  • 5587 replies
  • January 7, 2025
Hey there ​@Elisher & ​@Neillappin, sorry to hear this.
Please try the following:
  • Go to Settings > Notifications> Phone> then turn OFF Badge App button. The red dot should disappear from the phone icon.
  •  Call yourself from another phone and leave a message > Call voicemail and delete your message.
  • Go back to Settings > Notifications> Phone> then turn ON Badge App button.
  • January 7, 2025
this has still not rectified the issue
thanks
Elisher
  • 5587 replies
  • January 7, 2025
Hey there ​@Elisher, sorry to hear that. Have you tried disabling voicemail via the iD Mobile app/website, and then re-enabling it?
  • January 7, 2025
Yes I have tried that also
thanks
Elisher
  • 8256 replies
  • January 7, 2025
Hi ​@Elisher,
Further troubleshooting will be needed with this.
I would advise contacting our Live Chat Team and they can check it out.
  • January 7, 2025
Hi, I’ve just tried this and still have the red dot showing. When I compare to my sons iPhone which is also on ID mobile , I have a blue dot next to the ‘Network provider Voicemail’ on the voicemail page, which he doesn’t have maybe it’s related to the problem?
  • 8256 replies
  • January 7, 2025
Hi ​@Neillappin,
What happens when you press call?
Do you have any voicemails on your number that haven’t been checked?
  • January 7, 2025
When I press call it takes me to my voicemail & voicemail settings  but it says there are no messages.
  • January 7, 2025
I’ve also tried turning voicemail off and back on but it’s doesn’t help
  • January 7, 2025
Same for me
  • 5587 replies
  • January 8, 2025
Hey there ​@Neillappin & ​@Elisher, we’re very sorry to hear the issue still persists.
We’d recommend contacting our live-chat via the link below to raise this with them, so they can troubleshoot further, or potentially raise further with our technical team:
