voicemail notification
I recently bought a phone from ID (Google pixel).  I ported my number.  Since my phone number has ported I have lost the voicemail icon.  I have set up the voicemail by ringing 1 from the phone.  However I can't select visual voicemail on my settings.  It is reading as the temporary number when I bought the phone.  I have tried changing it to my number but it won't allow me to.
Best answer by RobRuth Hall
No as this is a new phone and new contract.  I managed to find under iD IN settings that I had 2 numbers registered so deleted the temporary one and it seems to be working now.
MZone
  • 1207 replies
  • March 20, 2025
Try performing a Network Settings Reset on your phone:
  1. Open ‘Settings’.
  2. Tap ‘System’.
  3. Tap ‘Advanced’.
  4. Tap ‘Reset options’.
  5. Select ‘Reset Network Settings’.
  • March 20, 2025
Unfortunately this didn't work ☹️
  • 4297 replies
  • March 21, 2025
Hey there ​@RobRuth Hall, sorry to hear that.
To confirm, is your number showing correctly in your phone’s settings?
Is voicemail enabled via the iD Mobile app/website?
Is the issue with visual voicemail, or normal voicemail or both?
  • March 22, 2025
When I check in settings under SIM the correct number is showing.
I can't see how to enable voicemail via the app/website.
When people ring my phone they can leave a voicemail - it's set up with my personal message but when I ring to check to messages there are none!  I have no where on the phone to check for voicemails I have to dial on to check.
  • 4297 replies
  • March 24, 2025
Has voicemail ever worked normally for you on our network before please?
  • March 27, 2025
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 381 replies
  • March 28, 2025
@RobRuth Hall  That's good you've managed to resolve your problem, if you need further assistance just post your issue in the community.
Joe
  • 4297 replies
  • March 28, 2025
Hey there ​@RobRuth Hall, we’re glad to hear all is resolved.
