Voicemail PIN
  • May 16, 2024
  • 163 views
I try and add a pin via my voicemail number, option 3 but there is no option…..
Best answer by Tyler C
Hey there @Leighvarnham, welcome to Community!
We’re sorry to hear you’re having issues with your Voicemail.
Please read the following link on how to set up Voicemail with us:
https://community.idmobile.co.uk/getting-started-with-your-id-mobile-plan-152/what-is-voicemail-and-how-do-i-use-it-45098#:~:text=How%20can%20I%20record%20a,prompts%20from%20the%20automated%20menu.
If the above doesn’t work, please let us know, and we’ll investigate further with yourself.
Kind regards,
  • 5855 replies
  • May 21, 2024
Kind regards,
