Voicemail problems | iD Mobile Community
Voicemail problems
  • September 18, 2024
  • 330 views
Recently changed from 3 to iD Mobile, porting my number. I am using an iPhone 12. I have set up voicemail and it is very erratic.
I am missing calls, which go straight to voicemail. Just now I got the text advising receipt of a voicemail, but cannot connect when dialling the voicemail number so cannot get to the message. However I can make other calls. Voicemail number auto sets on +447782333123.
I have tried a soft re-set on the phone, toggling Airplane mode, toggling WI-FI calling, taking out and reinserting the SIM card, but no luck.
Help please!
Best answer by Antinchip
Matthew, thank you for your input. I have had no response at all from the technical team.
Meanwhile I tried the SIM card in my old iPhone 7 plus and everything worked fine. Possibly something to do with the settings on my iPhone12?
After a day or so I put the SIM card back in my iPhone 12 and the problem seems to have gone away. Perhaps the technical team intervened remotely, or it was just a temporary glitch. All good for now, thank you.
Cheers
Support have escalated this to the technical team since it could not be resolved by the agent.
  • September 23, 2024
@Antinchip - Hope the technical team are able to support. If not, pop back here and let me know! Thanks.
Cheers
  • September 24, 2024
@Antinchip - glad you’ve resolved your issue. Thanks!
